Fuse6 Posted November 20, 2022 Report Share Posted November 20, 2022 (edited) Most of you may already know this about how to clean up the map after you plan your route but l just discovered it today by accident. In Service menu had ACCOMMODATIONS box checked. Did the planned route selecting places wanted to stay at. http://quebecrider.com/forums/uploads/monthly_2022_11/DA34DA6D-D295-4DCA-AB74-F384B624E322.thumb.png.8a9f0d3423df5bdda79b3e95e236a28d.png After completing plan went back into Services menu and UNCHECKED the Accommodations box. http://quebecrider.com/forums/uploads/monthly_2022_11/F16C672E-76A4-47A2-972F-FEADF75CB54C.thumb.png.eed4ccd832ce1c922890d5ef7f721565.png Map is then cleaned up and only shows hotels you plan to stay at. http://quebecrider.com/forums/uploads/monthly_2022_11/256E7429-D411-45D0-8789-DCFAC4EEDA80.thumb.png.f734facafb228dbb7a38d26e74d6c5ae.png Edited November 21, 2022 by Fuse6 PLAYHARD 1 Quote Link to comment Share on other sites More sharing options...
Fuse6 Posted November 20, 2022 Author Report Share Posted November 20, 2022 How do you make the pics show up in the post? When composing the post the pics download then l hit insert. Pics appear in the draft. After l submit post just the pic links is appearing. PLAYHARD 1 Quote Link to comment Share on other sites More sharing options...
PISTON LAKE CRUISER Posted November 20, 2022 Report Share Posted November 20, 2022 4 hours ago, Fuse6 said: How do you make the pics show up in the post? When composing the post the pics download then l hit insert. Pics appear in the draft. After l submit post just the pic links is appearing. You do not have to hit insert. Just hit the submit button when you are ready and the picture should be in the post if you review it. PLAYHARD and Fuse6 1 1 Quote Link to comment Share on other sites More sharing options...
markusvt Posted November 21, 2022 Report Share Posted November 21, 2022 Go back and edit the post and remove the pictures from the body and save. Not your fault, terrible forum software. Fuse6 and PLAYHARD 1 1 Quote Link to comment Share on other sites More sharing options...
