iceman Posted January 6, 2017 Report Share Posted January 6, 2017 Took this from another site. Interesting read on grooming. Jean Guy tell us if you agree. A great write up from a club from MaineHave you ever wondered why the groomer wasn’t out last night? Everyone has had a day where the trails weren’t as smooth as the day before, and you just can’t understand why. Well, here’s a little insight into trail grooming. * While most clubs that operate groomers are funded by sled registrations, gas tax refunds and membership dues, or the state/province, the guys running the groomers are quite often (almost always) volunteers. They’re up all night so you can have your fun the next day. They understand the importance of tourism and the impact snowmobiling has on their local economy, and they often share your passion for riding. Show them your utmost respect and don’t try to destroy the hard work they’ve just put forth. Remember, groomers have the right-of-way, not you. * The most important requirement for effective trail grooming is to have the snow at the correct temperature. The ideal grooming temperature is between +23o F and -5o F (-5oC and -20oC). As snow is collected in the drag, it has to be able to flow, like flour. As we all know, once the temperature gets close to 32oF (0oC) snow begins to stick together. Instead of flowing out under the rear pan, the snow builds up in the drag until it spills out over the top in large chunks or balls. These large chunks are dangerous when they freeze in the middle of the trail. * So you have a fresh 6” (15cm) of snow fall overnight. How come the groomer is not out? In order to groom effectively and make the trail more durable, the idea is to cut the mogul off completely, not just fill in the void. Moguls have a memory. If you just fill in the void with new snow, by the time half a dozen snowmobiles run over it, the new snow settles and the mogul is back again. When you groom fresh snow, the drag can’t be lowered deep enough to cut off the mogul because snow collects faster than it can flow out under the rear pan. Again, the drag fills up and spills snow out over the sides. After a fresh snow fall it’s often better to let the snowmobiles run it in and knock the air out of it. Then when the drag processes this finer snow, it packs much tighter. Often times, fresh snow means the groomer tractors can not pull as heavy of a drag, either. Lighter, smaller drags don’t pack the snow as hard nor do they cut the bumps as well. A trail may be groomed right after a snowfall, but it usually will not hold up nearly as well as after the snow has been packed and then cut. * Most grooming is done at night because it’s safer and more effective. Safer, because there are usually not as many snowmobiles on the trails, and when there is, the bright lights of the groomer are visible long before the machine itself. Grooming at night is more effective because it’s usually colder and the snow sets faster. Also, the longer the trail sets before too many snowmobiles ride over it, the longer it will last. Set up takes anywhere from two to six hours, depending on temperature and moisture content of the snow. Generally two to six or even more than ten hours may be needed for the freshly groomed trail to set up to where it is durable and will hold up to heavy snowmobile traffic. * For longevity of trail grooming, it is best to avoid riding a snowmobile on freshly groomed trails for at least two hours after the groomer passes. If possible, choose an alternate route to help improve the quality and durability of the fresh groomed trail. Avoid following directly behind a groomer because it immediately destroys the smoothing just performed by the drag. If you come up behind a groomer and the operator beckons you to go around, that’s the main reason, to allow him to groom without snowmobiles on the trail enabling effective trail set-up. He wants you in front of him, not behind him! * If you come across a “soft” or freshly groomed trail and you must use that route, try to minimize your impact on the trail: slow down; try to stay off the fresh grooming if the trail is wide enough to safely do so; operate only at the outside edge of the fresh grooming; ride in single file versus having everyone in the group take a different path on the fresh grooming; and don’t purposely fishtail or power through the soft snow. Do as little damage as possible by backing out of the throttle and reducing your impact until you get off that trail or pass the groomer. Better yet, turn around and take a different route. The mentality that “someone else will tear it up if I don’t” is what leads to a poor riding experience for all but the first few sleds to come through. * Grooming is usually not scheduled during heavy snowfalls or storms. Operator and snowmobiler safety are of principle concern, but it is also not productive to operate in these conditions. Sleds will soon pack it down, and the resulting groom will be far more effective. * Cold temperatures must also be considered for operator safety in case of equipment problems. Less miles of trail will get groomed in extreme conditions. As the temperature drops below -5oF (-20oC), steel starts to get brittle and equipment is more susceptible to breakage if it strikes a solid object such as a stump or rock. Although the groomer operator usually has communications equipment and warm clothes, waiting for a snowmobile ride 25 miles (40 kilometers) in the country at 3 AM can be a very uneasy feeling. * Understand that aggressive riding styles can impact the quality and smoothness of the trails you ride on. Fast starts and stops, powering through curves, paddle tracks, carbide runners, traction devices, and powerful engines can all combine to destroy the smoothness of a trail. So the next time you hit the brake or the throttle, think about how much damage you have innocently contributed to destroying the trails you would really prefer to be smooth. Try to not spin your track during acceleration or lock your track during braking. * Snowmobiles are much smaller and much more maneuverable than groomers, so always yield to a groomer. Always slow down * When approaching an oncoming groomer on the trail, slow down and move your snowmobile to the far right side of the trail. Realize that the grooming drag or tiller behind the grooming tractor may be very wide, and might extend wider than the tracks of the tractor and can essentially take up most (or all) of the trail’s width. If the trail is narrow or winding, you may need to stop at the far outside edge of the trail to let the groomer pass. When possible, pull off of the packed section of the trail completely. It is your obligation to get out of his way. * Anytime and every time you have the opportunity, tell a groomer operator how great of a job they’re doing. Remember, most are volunteers and many love to ride, just like you. They need to hear your appreciation if you truly enjoy riding smooth trails, or to simply have trails to ride on at all. The groomers are often the ones who help brush and sign the trails as well. They need as much help and appreciation as we can all give them. Hopefully this gives you a little insight into grooming. So if you see the groomer parked some day, it might not be ‘broke down’, we may be waiting for the right time Consider joining a club and or volunteering. Many hands make light work!!!Ride safe and let's have a great season!!! Scranton1 and im4snow 2 Quote Link to comment Share on other sites More sharing options...
timbo Posted January 6, 2017 Report Share Posted January 6, 2017 Very Good Article!!!! Hopefully, we will all take heed! Quote Link to comment Share on other sites More sharing options...
revct1 Posted January 6, 2017 Report Share Posted January 6, 2017 Our hats off to all the groomers that but in the endless hours to make our sport more enjoyable! Thank you and cheers Jack & Sandi Florida Snowman 1 Quote Link to comment Share on other sites More sharing options...
groomer Posted January 7, 2017 Report Share Posted January 7, 2017 great article !!! i like the part '' moguls have memory '''...very true !!! jean-guy Quote Link to comment Share on other sites More sharing options...
M21 Local Posted January 8, 2017 Report Share Posted January 8, 2017 Groomers are a blessing Everytime i cross one that is stopped i make a special effort to thank the guy and ask him if he is the need of anything. I make a special effort to show my appreciation and so do my byddies. Often enough the guy has a local knowledge of where i am going and has suggestion that i take into consideration. No time wasted there... Quote Link to comment Share on other sites More sharing options...
