MFARJM Posted June 1, 2011 Report Share Posted June 1, 2011 I HAVE A VIBRATION/RATTLE NOISE BETWEEN 3900 AND 5000 RPM ON MY 2011 1200 4 STROKE. IT SEEMS TO BE GETTING WORSE AS MILEAGE INCREASES. I NOW HAVE 2766 ON IT. IF I REMOVE THE DRIVE BELT I CAN HEAR IT BETTER AND IS NOISIER WITH CLUTCH SIDE COVER OFF. IF I PUT A STETHASCOPE ON CRANKSHAFT HOUSING ON CLUTCH SIDE, IT'S VERY NOISY. MY FRIEND HAS THE SAME SLED WITH ABOUT 3500 MILES AND FOR THE FIRST 1000 MILES HIS WAS NOISY LIKE MINE BUT NOW IS QUITE. DEALERSHIP OPENED CLUTCH AND FOUND NOTHING WRONG. DIDN'T HEAR A PROBLEM. I STILL THINK ITS THE PRIMARY CLUTCH. ANY COMMENTS? THANKS, JEFF Quote Link to comment Share on other sites More sharing options...
Saguenay Bill Posted June 1, 2011 Report Share Posted June 1, 2011 I HAVE A VIBRATION/RATTLE NOISE BETWEEN 3900 AND 5000 RPM ON MY 2011 1200 4 STROKE. IT SEEMS TO BE GETTING WORSE AS MILEAGE INCREASES. I NOW HAVE 2766 ON IT. IF I REMOVE THE DRIVE BELT I CAN HEAR IT BETTER AND IS NOISIER WITH CLUTCH SIDE COVER OFF. IF I PUT A STETHASCOPE ON CRANKSHAFT HOUSING ON CLUTCH SIDE, IT'S VERY NOISY. MY FRIEND HAS THE SAME SLED WITH ABOUT 3500 MILES AND FOR THE FIRST 1000 MILES HIS WAS NOISY LIKE MINE BUT NOW IS QUITE. DEALERSHIP OPENED CLUTCH AND FOUND NOTHING WRONG. DIDN'T HEAR A PROBLEM. I STILL THINK ITS THE PRIMARY CLUTCH. ANY COMMENTS? THANKS, JEFF Jeff I see you posted the same question on dootalk and two guys have replied. Check out the links they posted. Lots to read about it. Get yourself some clutch tools from C-T Powersports so you can fix it yourself. Bill Quote Link to comment Share on other sites More sharing options...
