revct1 Posted January 1, 2017 Report Posted January 1, 2017 Hi Alain. We went by Bernieres in the truck last week on our way to Lac St Jean. There was construction in the big parking lot and Sandi did not see the lock up for the trucks. I don't know if you were planning on using it, but it may no longer be available. Happy riding. Jack & Sandi Quote
Snobeeler Posted January 13, 2017 Report Posted January 13, 2017 Need coordinates for Barrage Gouin if anyone has them. Thanks Quote
Ike Posted February 7, 2017 Report Posted February 7, 2017 Anyone know if the latest Tilou Biscuit Mapset can be made to use as an overlay that is transparent? It seems to block out my topo basemapping. Using Garmin Mapsource and/or Basecamp and a Garmin Montana 650t. Thanks. Ike Quote
markusvt Posted February 8, 2017 Report Posted February 8, 2017 There are (2) maps that get loaded on your GPS, try selecting one or the other only? Quote
formula rob Posted February 9, 2017 Report Posted February 9, 2017 I have been trying to load the 2017 map version onto my Montana 650, I have the 2016 version on it already. When I load it through map source it says it has loaded but then I don't see it as a choice. I only see the 2016 version to pick from. I am reluctant to remove the 2016 version until I have the new one installed. Do I have to remove the 2016 map before I can see the new one? Quote
revct1 Posted February 9, 2017 Report Posted February 9, 2017 I read somewhere on here a while ago that you do have to remove the old one. Apparently two versions don't play with each other nicely. I am not an expert on this though. Jack & Sandi Quote
markusvt Posted February 9, 2017 Report Posted February 9, 2017 (edited) Nope. Both maps are part of the package for 2015 and up I think one is mainly the trails one is mainly the overlays both get loaded at the same time and most GPS's the older versions will be removed automatically. Use base camp, way better at most things then map source. Two clicks and the new maps will be on your GPS. Edited February 9, 2017 by markusvt Quote
Ike Posted February 9, 2017 Report Posted February 9, 2017 I got it! I cut and pasted the directions from the PDF (in French) into Google Translate and was able to figure it out. There are two maps in the set. The one block with the text "Sentiers Motoneige Quebec" just has the trails in it with a transparent background. If you already have a background map that you want to use, just pick that block; otherwise if you pick BOTH blocks of maps to transfer you will get their generic background map that will overlay what you already have effectively blocking out or covering your existing / preferred base map. At least this is what I've found on my Garmin Montana 650t. Ike Quote
markusvt Posted February 9, 2017 Report Posted February 9, 2017 There's an echo in here Glad you got it. Quote
formula rob Posted February 10, 2017 Report Posted February 10, 2017 Do you have to take the previous versions off before the new one will load Quote
Ike Posted February 10, 2017 Report Posted February 10, 2017 I cleaned all but the base files out of mine before I figured it out. I was using TrakMaps prior to this. Maiden voyage for the Tilou Biscuit mapset starts tomorrow morning!! Quote
markusvt Posted February 10, 2017 Report Posted February 10, 2017 2 hours ago, formula rob said: Do you have to take the previous versions off before the new one will load I have never seen this to be the case on any Garmin GPS I have put them on with Basecamp, and I have done a lot of them. Quote
formula rob Posted February 14, 2017 Report Posted February 14, 2017 Thanks very much, Base Camp is the trick, I was using Map Source, it worked as soon as I installed it using Base Camp. markusvt 1 Quote
attacker Posted February 19, 2017 Report Posted February 19, 2017 Does anybody if the same maps that are good for the Garmin montana will work for the Garmin Zumo 660. Quote
gkw Posted February 19, 2017 Report Posted February 19, 2017 2 minutes ago, attacker said: Does anybody if the same maps that are good for the Garmin montana will work for the Garmin Zumo 660. Yes, they will work, but if you haven't bought the Zumo yet, I would suggest stick with the Montana. Chk out the threads on Dootalk. GW Quote
attacker Posted February 19, 2017 Report Posted February 19, 2017 I already bought it I thought they were supposed to be better and I wanted to use it for the motorcycle. A friend tried loading the Quebec maps and the GPS says it's loaded but won't show the trails Quote
markusvt Posted February 20, 2017 Report Posted February 20, 2017 It works perfectly, no problem. Make sure you have them selected in the maps, and scroll into Quebec to see them. Quote
markusvt Posted February 22, 2017 Report Posted February 22, 2017 (edited) New Update as of 2/6/2017 Snowmobile trail Tilou Biscuit version 2017 v9.01 Continue to send corrections at: sentiers.motoneige@live.frHere are the links: Mac: https://drive.google.com/open?id=0B8...lRWQ2lpcTJqeTAPc: https://drive.google.com/open?id=0B8...kdWZF9aeHU0UUkAndroid: https://drive.google.com/open?id=0B8...XpEdkh5MTczeFE Edited March 12, 2017 by markusvt actionjack and revct1 2 Quote
revct1 Posted February 22, 2017 Report Posted February 22, 2017 Thanks Mark and also thanks to Tilou and Biscuit for their dedication. It is very much appreciated. Jack & Sandi attacker 1 Quote
CaptinMidnight Posted March 3, 2017 Report Posted March 3, 2017 Good morning everybody, I need a little expertise. I'm trying to put the maps on a garmin gps I've downloaded all the up to date map files and basecamp here's my problem. The only map I can load on the gps has the background behind the trails, which looks like it is the Senteirs Motoneige 2017 v9.01 disk image file. When I go to basecamp that's the only one that shows up in maps dropdown menu. Now reading on this thread I'm getting the idea there should be 2 files one with background and one without. I've also just right clicked on the file and "send to garmin" and then put the file in the map folder without even using basecamp and that works too but I can't seem to find the file without the background. Any help would be great. Thanks Quote
easyrider Posted March 5, 2017 Report Posted March 5, 2017 Markus, Thanks for the link to the latest update, 9.01. You are a huge asset to the snowmobiling community. M21 Local and markusvt 2 Quote
