MrGutz Posted October 17, 2017 Author Report Posted October 17, 2017 Update: There are several versions of the Skidoo 670, we have the oldest modern version of the crank. Unfortunately I have had a 2nd gen replacement from Skidoo in a box, I've had it for a while and did not know that there were a so many versions. I sent it off to the Crank Shop to have them swap a few things around, of course..... I was able to install the fuel lines and new high volume pump: The The Rotary Valve shaft and RV Gear from Sea-Doo (Beefier): I'm opening up the chassis to allow even longer travel of the front suspension, 12+ inches of Travel. A little clean up and some paint and it is ready to go! On to mounting the NOS Bottle and a new custom tail light! Later GutZ 800steve and Scranton1 2 Quote
800steve Posted October 17, 2017 Report Posted October 17, 2017 1 hour ago, MrGutz said: Update: There are several versions of the Skidoo 670, we have the oldest modern version of the crank. Unfortunately I have had a 2nd gen replacement from Skidoo in a box, I've had it for a while and did not know that there were a so many versions. I sent it off to the Crank Shop to have them swap a few things around, of course..... I was able to install the fuel lines and new high volume pump: The The Rotary Valve shaft and RV Gear from Sea-Doo (Beefier): I'm opening up the chassis to allow even longer travel of the front suspension, 12+ inches of Travel. A little clean up and some paint and it is ready to go! On to mounting the NOS Bottle and a new custom tail light! Later GutZ Gotta love them old bologna slicers. Quote
Shane Posted October 18, 2017 Report Posted October 18, 2017 This has been an awesome thread to read and a HELL OF A WAY to return to QR! Thanks Mr. Gutz! You guys from Team Marmalade are the BEST! Quote
Sledwhore Posted October 18, 2017 Report Posted October 18, 2017 I have one major complaint.....Sugar Free??? Sugar is the human NOS... Quote
MrGutz Posted October 19, 2017 Author Report Posted October 19, 2017 Well... Due to some altered plumbing, sugar is a big no-no. But I did taste some real ice cream last week and it was soooooo good. GutZ Shane 1 Quote
Triggerhappy Posted October 19, 2017 Report Posted October 19, 2017 11 hours ago, MrGutz said: Well... Due to some altered plumbing, So you had a Bruce Jenner done....? Shane 1 Quote
MrGutz Posted October 20, 2017 Author Report Posted October 20, 2017 I do look better in a skirt and heels now but...... no just a Gastric Bypass. GutZ 22 hours ago, Triggerhappy said: So you had a Bruce Jenner done....? Shane 1 Quote
Sledwhore Posted October 22, 2017 Report Posted October 22, 2017 I hope this warm weather's not slowing uguyz down.........when's the heart implant scheduled? Quote
MrGutz Posted October 23, 2017 Author Report Posted October 23, 2017 15 hours ago, Sledwhore said: I hope this warm weather's not slowing uguyz down.........when's the heart implant scheduled? It actually has helped a bit. The Front Suspension geometry has been an issue (Never designed for Huge Travel), I believe with the warm weekend I was able to set it as close to perfect as I can get without redesigning the front clip. The Crank is still at the Crank Shop, NOS Bottle is being re-certified, BUT the M-20 is acting like it's jammed I believe it's the coupler blocks. Things are moving along. I'll post a few more pics later. GutZ Shane 1 Quote
MrGutz Posted October 23, 2017 Author Report Posted October 23, 2017 Pictures: Coupler Blocks New Digital Tach to tune the Clutch Assembled and tuned Front Suspension and Snowboard Size Skis from Simmons. Crank is on the way back from the shop, trailer to be picked up on Sat Until Later. GutZ Shane and PLAYHARD 2 Quote
800steve Posted October 23, 2017 Report Posted October 23, 2017 Hey Gutz is this sled going around the lake this year? Quote
PLAYHARD Posted October 23, 2017 Report Posted October 23, 2017 2 hours ago, MrGutz said: Snowboard Size Skis from Simmons. I wore out a pair of those Gen 3's. Wings give float when you need it. Up out of the way when you don't. Quote
PLAYHARD Posted October 23, 2017 Report Posted October 23, 2017 I never did get around to putting on those scratcher plates. Quote
MrGutz Posted October 24, 2017 Author Report Posted October 24, 2017 2 hours ago, 800steve said: Hey Gutz is this sled going around the lake this year? It may make it, but an over-bored, Ported, NOS injected 2 Stroke...hmmmm.... Did I mention 8-10 MPG? We will see! GutZ 182ray and Shane 2 Quote
MrGutz Posted October 24, 2017 Author Report Posted October 24, 2017 1 hour ago, PLAYHARD said: I wore out a pair of those Gen 3's. Wings give float when you need it. Up out of the way when you don't. He's already planning to find some deep snow to test them. That never bodes well.... GutZ Shane 1 Quote
MrGutz Posted November 6, 2017 Author Report Posted November 6, 2017 Next Update! I should not seem so positive... so with the M20 in the chassis on 128 Rails I thought it was ready to go..... It would not compress so I contacted FAST. After several back and forth with Brian we determined that the rails are Polaris and Not FAST ones. You may say wwhhaatt? I thought Polaris used the M-10? Polaris Licensed the 121 "Directly" from FAST, the 127\128 was created using that license and is not supported by FAST because they changed the geometry. The rails if you put them on the ground and give them a quick once over they look like the are identical..... BUT the suspension arm connections to the rails are about 1 inch closer together on the longer 127/128 rails. I could have made them work but I feel it would have alter the coupling too much for a consistent ride. I found that Tracks USA makes billet 4 inch extensions for M10 Suspensions!! But the Polaris Version.... so like EVERYTHING else on the sled it will be custom. Next! Found a place to fill the NOS tank! Yaa! They said it needs to be tested, BOOO! 3 different places to try and get it Certified and last place said they can certify it! So it failed! Fudgicles!!! Not just a tasty treat. I guess the carbon fiber tanks are so thin that ANY scuff or abrasion will fail it. New one is aluminum, because to replace the fiber one is 600.ish. But a custom AC\DC converter came in, the USB connector came in, the crank is back form the Crank Shop and I'm starting the engine assembly! We took delivery of a new trailer!! And yes there is a problem.... Not with the trailer but the Mass Registry. Later GutZ Shane 1 Quote
Shane Posted November 11, 2017 Report Posted November 11, 2017 Team Marmalade never fails to disappoint!!!! Quote
MrGutz Posted November 16, 2017 Author Report Posted November 16, 2017 Update New NOS Bottle arrived and is being certified, Crank and Case are together, Unfortunately I've been laid up with Gout\SeudoGout (Not sure how) so I've been slow to do anything more. Maybe tomorrow I'll get back on it. Sneeky NOS (Fits right in the Seat) GutZ Shane 1 Quote
MrGutz Posted November 23, 2017 Author Report Posted November 23, 2017 Update: NOS Bottle Certified and Filled! Turns out, in true RR tradition, the Crank has oversized piston pin bearings, So I measured and ordered them, I hope the crank works after all this BS!!! M-10 is torn out, Re-Railed, Reassembled, Airline run to the Front Rear Shock, Almost put back into the Chassis. Pistons are marked up for the mini blowholes for the exhaust bridge. Block is just about ready to go together. ** Removed the Receiver Pin Lock from Truck , Lock was too corroded to open, it took 10 Seconds with a Battery SawZall and used blade from Harbor Freight. Later GutZ Scranton1 1 Quote
MrGutz Posted November 30, 2017 Author Report Posted November 30, 2017 Update: While the Mrs was at a Craft Fair I used the sink to do a final cleaning of the cylinders and pistons. I was able to mark and drill some blow holes to lube the Exhaust Bridges too. I upgraded the Cylinder Bolts and Washers, for maximum Debris and Shrapnel-ing Effects! Also Ported the 800r YPipe and cleaned up the flow. I assembled the Block last night, I'll see if I can get pictures tonight. Later GutZ Quote
MrGutz Posted January 14, 2018 Author Report Posted January 14, 2018 Well, Due to life and the COLD (No Garage) weather, the last few items to fit and customize have gone slow. The exhaust is causing a few fitment issues. I'm going to try and test it in QC later this week! Or not..... GutZ Quote
NSHM Posted January 14, 2018 Report Posted January 14, 2018 The moonshiners use oatmeal paste to seal their leaks.Do you use marmalade to seal the exhaust leaks? SnomoGary 1 Quote
MrGutz Posted January 14, 2018 Author Report Posted January 14, 2018 It's frozen so....maybe... I do need something to seal it up. GutZ Quote
