groomer Posted November 24, 2008 Report Share Posted November 24, 2008 last week i bought a new computer and since then it has been hell !!! ha !! ha !! i use irfanview to post pics on forums .so downloaded the new version (4.2) ,tried to post a pic ,but instead of being between 30 k and 100k , im up to 900k !!! way too big !!! tried a few times and always the same problem. deleted the new version and went back to the old version .same problem again .this morning downloaded the new version again ,same problem . last night went to check with the computer of my brother and both versions were working !!! i used the mininal size 640 x 480 and i m up to 900k . i can t figure out where the problem is ???? any ideas??? can someone help me ???? thanks !!! groomer !!! Quote Link to comment Share on other sites More sharing options...
MrGutz Posted November 24, 2008 Report Share Posted November 24, 2008 is it Vista or XP? Quote Link to comment Share on other sites More sharing options...
groomer Posted November 24, 2008 Author Report Share Posted November 24, 2008 is it Vista or XP? xp !!! Quote Link to comment Share on other sites More sharing options...
MrGutz Posted November 25, 2008 Report Share Posted November 25, 2008 i will download and test it, it sounds like the color depth may be too high 16bit, 32bit, etc... can add a great deal of size to a picture file. Quote Link to comment Share on other sites More sharing options...
MrGutz Posted November 25, 2008 Report Share Posted November 25, 2008 seems to work for me.... -open the image -image -resize/resample -640x480 -save as (had to choose JPG, default is BMP(usualy a larger file format)) -AOK (498k to 60k) check the file type when you "Save As", make sure it's jpg. let me know. Quote Link to comment Share on other sites More sharing options...
groomer Posted November 25, 2008 Author Report Share Posted November 25, 2008 thanks mr gutz !!! just checked and i was nt ''settled '' to jpg file . i ll try one later . thank you very much !!! merci !!! groomer !!! Quote Link to comment Share on other sites More sharing options...
MrGutz Posted November 25, 2008 Report Share Posted November 25, 2008 also try try reducing the quality when you save it, there was a sliding bar when I created the pic, it was at 80% but you could try 50? Gutz Quote Link to comment Share on other sites More sharing options...
groomer Posted November 25, 2008 Author Report Share Posted November 25, 2008 ya , i know about that bar .usually it s between 70 and 80 % thanks again for your time !!! groomer !!! Quote Link to comment Share on other sites More sharing options...
Snobeeler Posted November 27, 2008 Report Share Posted November 27, 2008 thanks mr gutz !!! just checked and i was nt ''settled '' to jpg file . i ll try one later . thank you very much !!! merci !!! groomer !!! Gutz has you going in the right direction. Its the save as format that is the problem. BMP uses no compression (larger file size). A 640x480 saved as JPG at 85% should end up below 40k size. Do not move the slider below 80% or your beutifull pictures will suffer. Also, do not leave both versions of the program on your computer. Quote Link to comment Share on other sites More sharing options...
groomer Posted November 27, 2008 Author Report Share Posted November 27, 2008 Gutz has you going in the right direction. Its the save as format that is the problem. BMP uses no compression (larger file size). A 640x480 saved as JPG at 85% should end up below 40k size. Do not move the slider below 80% or your beutifull pictures will suffer. Also, do not leave both versions of the program on your computer. hi snobeeler !!! thanks for the advice !! groomer !!! Quote Link to comment Share on other sites More sharing options...
